Lock axis with move tool
Hello, for those of us who work with bas-reliefs, it would be very helpful if the move tool could be locked on certain axes. If we want to move certain areas simply to add volume, we want the tool to only act on the Z-axis. For this, it’s necessary to lock the XY axis so that the movement only affects the Z-axis.
Right now, the most we can do is use the normal modifier and very carefully look for a point that is completely parallel to XY so that the movement only occurs along Z.
