Lathe & Tube have been available for the ADD primitive menu for some time now - unfortunately these two primitives are missing from the insert tool. It would be great if these two primitives could also be inserted via Insert.
The insert tool is very practical for using primitives - EVEN FOR THE TUBE.
And it would make a lot of sense for Lathe.
But what would it insert? Those two primitives require more parameters to be added before they exist - a path for the tube & an axis / profile for the lathe.
Best way to use these with insert is to create tube / lathe and then insert instance of them.
