Why can’t the Insert tool simply work directly in the viewport? e.g. like tube… When I work off-center, the Add Primitive tool is basically always a hassle because the scaling is off, and I often end up placing the object far away and then have to move it into position. There are workarounds using Insert and the Gizmo, but it would be much better if the Insert tool could also work directly in the viewport.
