I think the eyedropper tool for the background color might be bugged (in new version program and web assembly)
i went to change the backgroundcolor via eyedropper and on WA is just went black while in the program it would change to whatever color i was trying to pick up with the paint tool (via long-press).
I don’t understand the issue, what is WA?
For me it’s working fine (you can ignore the cube preview though)
Wa = web assembly sorry!
I hope its visible what im doing i was click&dragging with my finger to pick the color up
I also tried coloring the object and it still jumped to black
i can record a video of the app too if needed on there it changes the background constantly when i use color-pickup via paintbrush ![]()
It’s the mobile version that matters, not wasm.
It works fine on my iPad.
Background doesn’t pick the material but the pixel color, so it’s normal that it isn’t “stable” if you pick a shaded mesh.
Picking the empty background to update the background color doesn’t make sense (except if you pick the reference).
Edit 1: Ok I understand the stuck issue, it will be fixed.
At first I didn’t catch that you were using long press, I thought you were “stuck” and you couldn’t move the camera or sculpt.
For now you can simply click the paint dropper icon and it should resolve the long press.
Edit 2: minor improvements but I’ll disable postprocess dithering when using dropper (it’ll at least fix the weird color feedback loop when repicking the same flat background color)
Ahh thank you! Sorry i wasnt clear & i had something coming up yesterday🙇♂️ but if you need any more info about my setup or anything ill try my best to provide it!
A smoother eyedropper workflow would definitely help, especially when switching between painting and material tweaking quickly. Even a small shortcut or hold gesture for temporary color picking would make sculpting feel more fluid. I sometimes use https://colorpickerimage.org/ to grab/reference colors from artwork before bringing them into Nomad, so having a fast built-in eyedropper matters a lot for consistency too.
There is already a key binding available, you can also make a custom window menu with this shortcut in it.
And there is also the option to long press when you select the painting tool (gesture menu).
