I’m building a body with shapes to try to get an idea of what I want, but the mirrored transparency is annoying and makes it difficult. Is there a way to reduce or disable transparency?
I think there is no option to switch this off.
If you choose the view tool, mirrored object a shown solid.
I am not a fan of the almost invisible mirrored part as well.
Since clicking view turns transparency on mirrored off, at least it should be easy to add in the option.
It’s easy but it would be a terrible idea.
You cannot pick or interact the mirrored object, that’s why it’s transparent, and that’s the core of the issue.
Otherwise I know I would receive tons of bug report (why can’t I interact with this mesh).
Hmm, what about offcolored instead, as a selectable option?( This way it’d be off by default.)
Not doing anyting unless the core of the issue is solved (mirrored object not being clickable).
