What gpu should I use?
I’m using i7 9700’s integrated graphics now. But will there be meaningful difference if I buy Dedicated GPU? And if there is meaningful differences, would gtx1660 be enough?
я пока использую для небольших работ и рендеринга ноутбук ryzen 7640hs с видеочипом radeon 760M, он гораздо слабее моего gtx1660 ti на большом ПК, но его мощности хватает для несильно сложных работ. Если есть возможность, то конечно же лучше иметь мощную систему с запасом. тестировал на своем старом ноутбуке на i5 4200u с 8Гб оперативной памяти, на нем программа еле работает.
You should see a difference by switching to a dedicated GPU, how much though is hard to say. I’m using a 1660 Super and it has held up fairly well despite it’s age. I can still play most modern games at 60 fps or more with medium to low settings, although it is becoming the bare minimum for more and more games. Sculpting wise, it is enough for me, I can sculpt on meshes with millions of polygons just fine. I haven’t tried sculpting on projects with more than 5 million polygons yet, as I haven’t had a need to. Of course CPU and RAM also matter for 3D software (I’m on a Ryzen 5 3600 and 16 GB DDR4 RAM).
My outdated specs have held up so far, but I would absolutely upgrade if prices were not so crazy right now. I’m guessing you are looking at a 1660 to save money? If you can swing it I would at the very least try to get a 60 series RTX (2060, 3060, etc). A 1660 will do the job for now, but probably not for much longer if you also game.
I’ve sculpted on everything from a 70$ Android phone to my current mini workstation, and even on my two mini PCs with old Ryzen 7 6800U APUs (Radeon 680m integrated graphics) running Nomad through Bluestacks, I was still able to comfortably handle 20+ million vertices. Nomad is mostly CPU, and memory bound as far as I know, but due to the way APUs share memory, they should honestly be more than adequate for all but the craziest workloads.
