Weird behavior Nomad Desktop
I am experiencing two distinct issues in Nomad Desktop, which may or may not be related to my graphics tablet:
  • Any input from the mouse registers instantly on the screen the inherent limitations of using a mouse, of course. If I use Alt+Tab to switch away from and then return to Nomad, I can resume working immediately using the mouse. However, if I return to the app using the stylus, Nomad runs in “slow motion” for a few agonizing seconds. It fails to register clicks correctly, and I have to wait for the cursor to finish its entire movement path before it re-syncs with the actual position of the stylus. The more I move the stylus while it’s in this slow-motion state, the longer I have to wait. Again, this does not happen when returning via the mouse; often, I have to switch back using the mouse first before I can proceed to work with the stylus.
  • Context menus triggered by the stylus do not stay on the screen. For example, when clicking and holding the Voxel Remesh icon to select a target resolution, it works perfectly with the mouse; with the stylus, however, I have to trigger the menu 5 to 10 times before it finally stay put on the screen, allowing me to adjust the resolution. The same issue occurs when confirming a remesh (which opens an “OK/Cancel” pop-up)—I have to click “Remesh” multiple times before the pop-up stays fixed on the screen so that I can interact with it. This isn’t limited to the Voxel Remesh feature; that is simply the most frequent example.
I’m not sure if all of this is reproducible or if it’s specific to my setup. I’m using Nomad 2.13 (both issues have been happening for a while now; they aren’t recent), Windows 11, and my display is a 24" 4K Huion.
Evidence
THE PLATFORM: Windows
NOMAD APP VERSION: 2.13
I can’t offer a solution, but I can confirm that I had exactly the same behaviour within Nomad when using my Huion Kamvas 24 Plus… I mean exactly the same. That was using the latest Huion driver, and with the Huion as the second display. I did a lot of troubleshooting, everything I could think of, but could not find a cure for that behaviour. I’m now back to using my Cintiq Pro 24 and all is well.
I hope at least this adds some weight to this report.
Windows 11 here too.
Cheers,
Val.
What’s the wintab settings?
Try it with both ON and then OFF (same in the huion driver).
I’m not sure what you mean
In the nomad menu (top left icon).
I thought everyone knew about wintab, almost every tablet has a toggle to decide which api to use (wintab vs the windows api, sometimes called windows ink!
That was it. Mine was toggled as auto and it was off on the driver. Thank you Stephane.
Perfect. Was Auto here too. All’s well now.
But did it work with YES or with NO? (or both, in that case something is wrong with auto)
Also on Auto, do you remember if the underlined value was YES or NO.
Mine worked with the NO option both on Nomad and the Driver
