iOS : Nomad 2.12.1
When using the view cube to rotate the view, you should be able to click on the cube and use it to rotate the object view. Front, Back, Left, and Right work as expected. Top and Bottom do not. They spin the object in the current view. Is this a bug or a setting that has changed?
