Device: iPad Pro (2022)
Nomad Sculpt version: 2.13
Category: Bug Report / VDM Capture
Hi! I’d like to report an issue I’ve encountered while trying to create a VDM brush from an existing sculpture.
I’m not sure whether this is a bug, a limitation of VDM, or something I’m doing incorrectly, but I’ve spent quite a while troubleshooting it without success.
What I’m trying to achieve
I sculpted a long, thin, curved organic shape and wanted to turn it into a reusable VDM brush so I could quickly add multiple copies to other models.
Steps I’ve tried
- Sculpted the original shape as an independent mesh.
- Used a Boolean operation to merge it with a flat base surface.
- Used VDM → Create → Capture to capture the sculpture.
- Applied the captured VDM to a densely subdivided mesh.
- Tried reducing the height of the original sculpture and capturing it again.
- Checked the VDM brush settings for options to improve the resulting geometry.
Actual result
The VDM captures the general shape, but the generated geometry appears heavily stretched, with noticeably poor polygon distribution.
The original sculpture is smooth and detailed, but the VDM-generated result has elongated polygons, especially along the curved and protruding sections.
Even when applied to a fairly dense mesh, the result is significantly less smooth than the original.
Reducing the height of the original sculpture did not sufficiently resolve the issue.
I also tried capturing the sculpture using a flat base, but encountered the same problem.
Note: The two protrusions visible in one of my screenshots are caused by symmetry being enabled. That is intentional and not part of the issue.
What I expected
I hoped the captured VDM would preserve the original sculpture’s shape and smoothness more accurately when applied to a sufficiently dense mesh.
Questions / Suggestions
- Is this expected behavior when capturing long, narrow, or strongly curved shapes?
- Is there a recommended workflow for capturing existing independent sculptures as VDM brushes?
- Is there a way to control the resolution or quality of VDM Capture?
- Could a future version provide better handling of heavily stretched geometry, or offer clearer guidance about the limitations of VDM Capture?
I understand that VDM works by displacing an existing surface, so some stretching may be unavoidable. However, it is difficult to determine whether the problem comes from capture resolution, the receiving mesh, or the geometry itself.
More documentation or user-facing guidance would be extremely helpful, especially for artists who are new to this feature.
I really appreciate the work being put into Nomad Sculpt. I use it regularly for sculpting, and I was excited to try the VDM feature.
I’d love to understand how to get better results with this type of shape.
Thank you for your time!
Screenshots attached:
- Original sculpture and initial VDM result I expect.
- Original sculpture and VDM result viewed from underneath, with wireframe enabled.
- VDM brush settings in Nomad Sculpt 2.13.
