Using the text tool to bring in shapes
Yesterday I asked myself this question; how to convert shapes to a font file (.ttf or .otf) so I could use the text tool in Nomad Sculpt to immediately have an extracted shape without using the tube nor the masking tool. Those tools are awesome but have some limitations, depending on what we want to achieve of course. Although since the latest update they can all have bevelling applied to them .. tube profiles can’t have holes; for this you need to use a boolean operation. And eventhough the mask tool does allow for complicated shapes and wraps greatly onto the underlaying mesh .. we need lots of poly’s in order to have sharp corners. Using quadremehser to lower the poly-count tends to smoothen those out. Enter the text tool and FONTSELF!
Fontself is an app that is actively developped by French people .. like Stephomi (huge thank you for all you do!). It’s an extra tool, it is fun and intuitive to use. Jennifer Nichols Art has made a very comprehensible tutorial about it on Youtube (https://www.youtube.com/watch?v=SqW43WWlUSU).
I share my discovery for those not aware yet of this possibility, because I do believe it can help some with their workflow and requirements. The app is only 20 €. It converts your alphabet to a .otf font format right on your iPad. It works 100% off-line and has no subscription!!! Does it has limitations? Yes, there is no realy symmetry nor radial symm for example. But they keep adding tools so who knows what brings the future.
The workflow is straightforward :
- create your shapes in Fontself (you can do more then letters) .. it’s vector based
- give your ‘alphabeth’ a descriptive name
- export them into a folder or send it directly to Nomad Sculpt (or even Procreate)
- add the text tool in NSculpt and type in the letter(s) corresponding to the shape(s) you want
- play around with the settings and if you like to have it wrapped around another shape, snapping can be your friend
Tip : to remember which letter corresponds to a certain shape, you can take a screenshot of your Fontself alphabet.
It’s not perfect but it works .. and it’s fun :slight_smile:
Elfriede
I added some screenshots. I hope they come through ..
Thanks for you explanation.
I tried this also with nomad with Digbat Fonts etc.
A few years ago I used this Font - Vector thing in Procreate to get Shapes - because it’s the only way to use SVGs inside Procreate.
But in fact I didn’t use it because you don’t have a preview like for the alphas.
I used IcoMoon : IcoMoon App
Hello Holger,
Thank you for your reply. I am so enthusiastic about this combo Nomad and Fontself (because no need for internet or any other third party app) I was wondering if there wasn’t a solution to this after all. After some thinkering I found it .. although visually it is limited to 3 and 5 letters corresponding to the word … NOM / NOMAD
3 because it is what shows when opening the font library in Nomad. 5 because as soon as you add the text tool in your project it shows NOMAD .. see screenhshots.
For those 5 shapes to be visually, you MUST use the letters corresponding to NOMAD or it wont work! That’s what I did yesterday, which you can see in the screenshot too as Test A.
And yes, one can still use the entire alphabeth but as you mentioned, there is no visual way to know, except for a screenshot you have to have at hand which is a bit cumbersome.
Also .. I like to take the opportunity to thank you for the tutorials you post on Youtube. I’ve learned quite a lot about what tools can do and how to use them.
Kindly .. Elfriede
