Hi, I use Nomad Sculpt to make custom grillz, and after the latest update my Mask/Extract workflow appears to have changed.
Before the update, I used the Mask settings with Extract selected, Height + Mask, Smoothness set to 51, and Sharp border selected. This gave me smooth edges that fitted my grillz model properly.
After the update, the interface now shows different Smoothness options, including All and Borders only.
My extracted grillz now have sharp, rough edges that don’t fit the teeth properly. I need help finding the equivalent of my previous settings.
My questions are:
- Has the Mask/Extract smoothing behaviour changed in the latest update?
- What settings now give the same result as the old Sharp border option?
- Is there a workaround or a way to restore the previous behaviour?
Thank you!
- Yes
- Show the problem, visually.
- No
Next update will likely fix your issues though, if the core issue is jagged borders.
So usually I use this tool to smoooth the boarders around the tooth. See how it is clean for the project. I can’t seem to find a workflow to fix this?
When is the next update we kind of need it now
Hi i also relied on this app for work, the whole app is ruined for me currently. Issue is not the jagged edges. Issue is that the extracted mask is not the shape/size that is should be. Where you can see the mask is how it is now, where the extract hugs the teeth perfectly is how it used to be. Is there any way to get the older version of the app? Ipad Air 2025
So many people are having the same issue there is literally no point of having the software right now for jewellers. Please can this be looked into and brought back asap
2.10? Maybe use the latest version, it’s 20 days old
Sorry but you guys are just bad at explaining because I simply don’t understand the issue.
Maybe show a before/after.
The whole point is the updated version doesn’t work?
The issue is that you’ve removed the Sharp border option when extracting a mask, and the new Bevel/Profile controls don’t give us the same result.
I’m attaching the before and after:
• First picture: the new version using the Bevel/Profile graphs.
• Second picture: the old version using Sharp border—the result we’re trying to get back.
We make jewellery and grills, so we need the extracted shell to hug the tooth with a clean, smooth border. The old option did that. With the new controls, adjusting the graphs either distorts the shell, pulls it away from the tooth or leaves the edges uneven instead of joining smoothly with the front.
It’s not just me. Our whole team has spent weeks trying different graph settings, and other people here are asking for the same feature back. This isn’t us just not wanting to learn the update—we’ve genuinely tried to make it work.
Being told we’re “bad at explaining” is frustrating especially when it was such a important feature
We’re asking you to bring Sharp border back because without this function the software is useless to many of us
Here’s before/after that shows the output visually and the settings.
“Height + mask” that would be “mask” in the new version.
I work in Dental and have used nomad for various restorations. Even I’m not sure what’s being asked for. Steph is right, “you guys are just bad at explaining.”
I played with it a little and I think I know what the complaint is:
When extracting the mask, it used to come out of the masked area, and had a nice transition from the mask border to the main extracted piece. To use a dental term- the emergence profile.
Now, the extraction shoots straight out and doesn’t transition so well. Looking at the picture below, notice the desired shape of the mask extraction, marked in blue and the orange dotted line (green arrow). The undesired shape is in yellow (red arrow):
Here’s another picture, showing the extracted mask with the same markings:
When playing with the graph, it adjusts the area between the mask and a spot that seems to be the thickness of the mask (circled in red). There doesn’t seem to be a way of making it come off of the mask and smooth into the bulk of the extraction, creating a smooth transition. The connection point circled in red, always remains and there doesn’t seem to be a way of changing it.
Again, I could be wrong on what the issue is. But playing with the mask extraction, this is what I found.
Here’s a video of it. The graph adjusts the area between the two white arrows, rather than smoothing the transition from the mask to the body of the extraction like it use to.
Sometimes it’s not easy to do a before / after video because you can’t go back in versions. So if you don’t have e.g. a nomad V2.8 you can’t show it anymore.
