Three Button Repeater Function macOS
Hello. I posted this question on Discord but it may have been too long. Can there be an option to assign one key in bindings for the three-button Repeater option after drawing a cloned stroke? Currently it requires option, control and shift. I understand if it is not possible. I was just hoping it would be an option since those buttons are assigned to other bindings. I can change those around if I need to. Thanks!
What does this do? i can’t even test it.
You don’t have to press 3 buttons - only 1 of them
I mistakenly thought you had to press all three of the listed buttons. Just as Holger_Schoenischka mentioned you only need to select one button after you clone the object.
@Freddie3D @Holger_Schoenischka Can someone please explain to me what does this do, I pushing all the buttons combinations I can in my mac and tablet trying it to do something. :sweat_smile:
I am trying all buttons and it change from the repeater to smooth alt for negative and control for mask. just really dont get it
Try this. Select the stamp tool. Then you will see clone at the top. Tap cone and it changes to repeater. As you grab the green selector button press one of the keys shows and as you drag it will repeat the stroke. It took me a few tries.
OMG this is crazy, this is a good feature, it should have a little more control but it is good
It is a very useful feature and I’m using it more and more. Glad it’s working for you. Have fun!
