Suggest changing the location of adding object functionality
The plus sign for adding objects should be turned into a separate first level menu, or when customizing the toolbar, the plus sign can be directly added. After clicking, the object to be added will be turned into a second level menu. The current add button itself is a second level button, which feels a bit cumbersome to operate
You can make a shortcut window with all ADD objects.
If all of them are added, the interface will be very messy. Just add a plus sign and click it to pop up a second level menu, which is not only neat but also convenient
Only a example…
How did you make this? It doesn’t need to stay on the desktop, do you use shortcut keys or not? I really don’t know this, thank you
Add new shortcut window - rename as : +
Checkbox on BAR.
Add all Primitives to the new shortcut window - resize as you want…
Place it on the screen - Tap to collapse/ expand
Understood, thank you. My desktop version is 2.9.29, which cannot set the dropdown triangle, so it cannot be folded. The tablet version is 2.8, which can be set in this way. I don’t know if it was changed in version 2.9 or specifically for the tablet version. If it was brought about by a version upgrade, this feature may have been canceled,If this feature was removed in version 2.9, I think the author should have added it again, it’s really useful
I used the webdemo for the video so 2.9.29 …
I’m using the desktop version of Nomad 2.9.29, and it works just as Holger described. You need to tick the checkbox first. Then you can click to open or close the shortcut window.
