Nomad Sculpt - Video manual - (latest add 2.12.2023) Beginner & Advanced Tutorials
Nomad Sculpt online Manual V.1.81 (12.8.2023) FB Group
Video Tutorials & Links to the Nomad Sculpt online manual.
1 Add primitives
Manual: https://nomadsculpt.com/manual/scene#primitive
Add primitive Tutorial Video:
2 The Gizmo
Manual: https://nomadsculpt.com/manual/tools#gizmo
Gizmo Tutorial Video:
3 Reproject - Textures to Vertex Color
Tutorial Video:
4 Reproject - 2D Mesh to other surfaces
Tutorial Video:
5 Avoid merging vertices when joining objects
Tutorial Video:
6 How to save / preserve masks on a layer.
Tutorial Video:
7 Unwrap nicer UV Maps.
Tutorial Video:
8 How to set the correct ratio for a image on a plane with UV as texture e.g. as reference 2D image.
Tutorial Video:
9 How to place stickes on other objects and merge the UVs.
! Turn OFF - two sided for the sticker plane.
Tutorial Video:
10 Reproject Textures from a Plane
Tutorial Video:
11 Bevel / Chamfer edges 1
Tutorial Video:
12 Bevel / Chamfer edges 3
Tutorial Video:
13 Voxel remesh narrow gaps or problematic zones
Tutorial Video:
14 How to use correct views with the view cube for off center objects in free space.
Tutorial Video:
15 How to save post process presets.
Tutorial Video:
16 Spiral & twist with the tube tool or curve repeater
Tutorial Video:
17 Tube profile
Tutorial Video:
18 Posing with mask + multiselection + Gizmo transform
Tutorial Video:
19 Gesture Indicator for the screen - screen recording
Tutorial Video:
20 New mask extraction features
Tutorial Video:
21 Brush Silhouette option
Tutorial Video:
22 Smooth Tool new options
Tutorial Video:
23 Gizmo & Symmetry in 1.78
Tutorial Video:
24 Mask - Gestures & shortcuts
Tutorial Video:
25 Displacement for textures UV
Tutorial Video
26 Symmetry & mirror per object
Video Tutorial:
27 Curve repeater & spiral
Video Tutorial:
28 Boolean
Video Tutorial:
29 Masking via layers
Video Tutorial:
30 Hightmap
Video Tutorial:
31 Pin Pivot
Video Manual:
32 Aligning to curve
Video Manual:
33 Better Pivot position
Video Manual:
34 About Color
Video Manual:
35 Reset Pivot & Symmetry
Video Manual:
36 About GIZMO / SYMMETRY / PIVOT & Object center / world center / symmetry center.
Video Manual:
37 Tube profile 1
Video Manual 37
38 Tube profile reference image
Video Manual 38
39 Tube profile - Hard surface 1
Video Manual 39
40 Tube profile - Hard surface 2 - symmetry / mirror
Video Manual 40
41 Lathe Tool
Video Manual 41
42 Reproject Text
Video Manual 42
43 Object positioning, aligning, snapping to other objects
Video Manual 43
Wow, as usual, your training is at the top. Thank you very much for sharing and your work.
Hi Good time everyone, unfortunately, I’m going wrong somewhere and I don’t understand. Can you give another example?
Update 2.12.2023
Those videos for Tube Profiles are awesome! :+1:t2:. That is going to be incredibly helpful! And using that to create an edge chamfer is also extremely useful! Thank you so much for these videos! :+1:t2:
@Holger_Schoenischka , I need to hire a tutor that could help me to create Nomad workflows in order to sculpt meshes from scanned people’s faces. Could you be that person? If so, would you contact me at drendrigo@gmail.com? Thank you in advance!!
Thanks for asking, unfortunately not. Nomad is just my hobby and I don’t have enough time for it alongside my normal work.
It’s an easy process, Nomad is perfect for processing scans. Workflow is as follows:
1/ Import scan & trim any unwanted parts
2/ Clone original scan & hide original
3/ Select clone & quad remesh instant, using a similar mesh resolution as original
4/ UV Unwrap atlas
5/ Bake to texture using from High-res
6/ Delete original scan & save result
Holger, i just realised my answer is in your video thread. I can delete if you want :+1:t2:
Please do not delete.
Thank you!! I will do it!!
