# Nomad Change Log
**URL:** <https://forum.nomadsculpt.com/t/nomad-change-log/139>\
**Category:** Lounge\
**Created:** [September 1, 2020, 10:58pm UTC](https://forum.nomadsculpt.com/t/nomad-change-log/139 "2020-09-01T22:58:04Z")\
**Showing post:** 53
**Post date:** [June 16, 2023, 7:15pm UTC](https://forum.nomadsculpt.com/t/nomad-change-log/139/53 "2023-06-16T19:15:33Z")
# 1.79
twist: fix spiral mode along with closed tube
twist: fix curve twist gizmo UI handler being sometimes blocked
boolean: add polygonal boolean
boolean: trim tool has now a proper boolean option
curve: Improve curve fitting algorithm to generate less points when hand-drawing curves
decimate: improve quality (easier removal of long thin triangle)
snap: use scene pivot only if the scene scene is visible on screen
snap: flip wasn’t working properly in some cases
postprocess: add dithering option (should be disabled when rendering an image with lot of flat color and no shading)
dynTopo: fix crashes when using dynTopo with connected topology and lock stroke mode
layer: fix trim or voxel remeshing duplicating too many layers when filling holes
render: fix incorrect fov during when rendering with non screen ratio
silhouette: view mode now works properly is the mesh is transformed
interface: improve performance when display many resources (alphas, textures)
depthMasking: fix top and bottom area filtering
project: fix saveAs new automatic renaming to not override existing project
_[View the full topic](https://forum.nomadsculpt.com/t/nomad-change-log/139)._
