# Nomad Change Log
**URL:** <https://forum.nomadsculpt.com/t/nomad-change-log/139>\
**Category:** Lounge\
**Created:** [September 1, 2020, 10:58pm UTC](https://forum.nomadsculpt.com/t/nomad-change-log/139 "2020-09-01T22:58:04Z")\
**Showing post:** 20
**Post date:** [March 26, 2021, 2:05pm UTC](https://forum.nomadsculpt.com/t/nomad-change-log/139/20 "2021-03-26T14:05:57Z")
# 1.46
tube: fix uniform quad density when there is only 2 points
tube: improve quad density (on turn, caphole, etc)
tube: fix “snap every point” option
file: avoid saving if an error occurs and displays an error banner when it happens
file: STL and OBJ export now exports mirrored primitives as well
file: reconstruct multires when loading a file (only if the highest level is less than 400k vertices)
voxel: fix voxel subtract mode quality
symmetry: line display is now correctly displayed
layer: correction of layer offset when applying a transform on the mesh (voxel, bake, etc)
merge: fix color being broken when simple merging meshes
color: allow hex color input
_[View the full topic](https://forum.nomadsculpt.com/t/nomad-change-log/139)._
