Subject: Feature Request – V-Curve Router Bit Brush with Adjustable Tip & Angle (Stylus Pressure = Cutting Depth)
Hi Stéphane and Nomad Sculpt team,
I’d like to request a new brush that simulates the cutting action of a woodworking V-curve router bit.
Key requests:
- V-groove cutting behavior – The brush should carve a V-shaped groove into the mesh, mimicking how a V-bit router cutter removes material, rather than just displacing or stamping it.
- Adjustable tip and cutting angle – Users should be able to define the tip width and the included angle of the V (e.g., 60°, 90°, 120°) to match real router bit profiles.
- Stylus pressure controls cutting depth – On a tablet with a stylus, pen pressure should directly control how deep the bit cuts into the surface, giving natural, tactile control over groove depth.
This would be extremely valuable for hard-surface and woodworking-inspired sculpting, where precise chamfers, grooves, and engraved lines are needed. I know other users have also asked for a proper chisel-style brush (see the existing forum thread on a chisel brush), so there seems to be real demand for this kind of tool.
Thank you for considering this!
Best regards,
MR.Add
