Would be nice if the measure tool get 2 Nodes - so you can edit the measure line and be able to reposition / snap start & endpoint.
And - when you tap on the value - edit VALUE Window - this way you can resize object based on measured distance.
When you change value e.g. 0.876 to maybe 15 then object should resize according to this distance - now object is 15 UNITS
