THE PLATFORM: iPad
NOMAD APP VERSION: 2.14
I’m using the layer tool, set to lock + radius mode (basically replicating stamp functionality), use layer data is checked on, and I’m on a new layer.
When I have radial symmetry turned on I’m finding inconsistent behavior in the build up at the intersecting points of the repeated pattern - sometimes they are going to the max height of the layer, but sometimes they stack up double height, and sometimes they mostly merge but a few vertices jump up to twice the height.
I could be doing something wrong, but I think I’ve done this in the past without issue. But I’m not sure how much intersection there was in the between the repeated stamps.
Hopefully this makes sense. Basically I’m trying to repeat a stamp radially so that it ends up being near seamless. In the past I’ve used the layer tool with the alpha with the radial symmetry turned high enough so that there’s overlap between each stamp, but that overlap is not always staying at the layer height.
