Hi everyone! I’m fairly new with Nomad Sculpt and 3D sculpting in general (I have some previous experience with 3D modeling in Blender).
Issue: Sometimes while sculpting on a high poly model (using the Crease tool for example) it is easy to forget that the z symmetry tool is active and the sculpting in the front is mirrored on the back of the model… sometimes I don’t notice it right away so it is easy to get carried away, to the point, I’m no longer able to use “Undo” without eliminating all the extra work I have done after… Using the Smooth tool still leaves a visible soft texture I don’t need on what should be an entirely smooth flat or rounded geometry
I have made this mistake a couple of times and I am not sure what the best way is to seamlessly fix the unnecessary sculpt/texture at the back of the model; any tips/ advice?
Thanks in advance! ^^
