I’m really curious about Nomad. I currently use Meshmixer for quick clean up of scanned body parts - it’s actually a perfect app for my workflow but it’s old, glitchy, and no longer updated. This pic is a heel (triangles) with a hole that needs to be filled. Is there a tool in Nomad to fill it quickly with the general anticipated contour intact? I don’t want to add a primitive and rebuild it or have a flat fill and recontour it, if that makes sense. Thanks!
Nomad has a - Fill hole option - it fills REAL HOLES in the mesh
but if the mesh has a very bad topology and maybe a hollow structure with thin walls - then hole filling doesn’t work…
and there are also other workflows to close holes … like smooth with dynamic topology - or front vertex trim or voxel remesh with a other mesh ….
But sometimes it’s hard to fix a very bad scan ….
Best is post a example mesh - then we can test and give feedback if hole filling works.
Okay, thanks for the response. I think there’s a trial version for desktop. Might try it out.
You can also use Web Demo to test - it’s the same app
