Edge Loop Equivalent in Nomad Sculpt?
Hello.
In ZBrush, I can use the Edge Loop (Crisp) function to create a new PolyGroup around the boundary of an existing PolyGroup, as shown in the attached image.
Is there a way to achieve the same result in Nomad Sculpt?
There is also another way to do this in ZBrush by holding Ctrl + Shift while moving the Gizmo.
I’m wondering if Nomad Sculpt has an equivalent feature or workflow that allows me to create a similar border around Face Groups.
Any help or suggestions would be greatly appreciated. Thank you!
There is no option for this in Nomad.
Only ugly workarounds here is my attempt on adding a extra loop.
It works somehow - but in fact it’s a disaster :joy:
Thank you for your reply!
I really appreciate you taking the time to make such a clear and helpful video! I’ll give the method you showed in the video a try as well!
I’ll look forward to seeing an easy-to-use feature like this being added in the future :joy:
Yeah, would be great to have a way to create edge loops within Nomad. For now, I use the recenty added Blender linking when I need to fine tune a mesh.
I tried a different approach. I extracted it with these settings, then split it by polygroups, deleted the two touching caps, and welded the remaining parts. Of course, it’s a long way to do it, but it’s possible…
>2ndHouse
It would be absolutely wonderful if this could be done directly in Nomad.
I’m really glad to learn how you’ve been working around this issue. It’s very helpful!
It looks like it’s about time for me to start learning Blender, too. :thinking:
>x_Polygon
Thank you so much for showing me the settings as well. That was a huge help!
I’m still trying to get familiar with all the new features in the latest Nomad update, so…
I’ll give your method a try, too​:saluting_face:
I’m not 100 % sure but I thought the shape was not mask extracted it looks like a polygroup extruded/pulled out of the mesh.
When you mask extract you have more options like e.g. wall divisions etc.
