# Easier way to Hollow models?
**URL:** <https://forum.nomadsculpt.com/t/easier-way-to-hollow-models/7021>\
**Category:** Tips, Tutorials and Help\
**Created:** [June 7, 2022, 5:44am UTC](https://forum.nomadsculpt.com/t/easier-way-to-hollow-models/7021 "2022-06-07T05:44:30Z")\
**Showing post:** 2
**Author:** ![RogerRoger](https://dub1.discourse-cdn.com/flex005/user_avatar/forum.nomadsculpt.com/rogerroger/32/33580_2.png) [@RogerRoger](https://forum.nomadsculpt.com/u/RogerRoger)\
**Post date:** [June 7, 2022, 6:35am UTC](https://forum.nomadsculpt.com/t/easier-way-to-hollow-models/7021/2 "2022-06-07T06:35:23Z")
You can use the Mask and Extract tools.
In a nutshell:
o Mask the part you want hollowed
o In the mask menu, set the Shell Thickness
- Positive number puts the shell inside
- Negative number puts the shell outside
o Tap Engrave/Emboss
The new shell will be a separate object.
o For the inner object, you’ll need to check the Inverse Culling option in the Materials menu.
o Turn off visibility of the inner object
o Select both parts
o Voxel merge them
You should now have a hollowed part.
_[View the full topic](https://forum.nomadsculpt.com/t/easier-way-to-hollow-models/7021)._
