Boolean Button selecting through to objects behind it…
THE PLATFORM: MacOs
NOMAD APP VERSION: 2.9.24
Using the Boolean button when it’s over the layers panel, as you press the button you sometimes “click through” the button and select the object behind it rather than executing the Boolean function.
I can’t replicate, are you sure it doesn’t trigger boolean?
Ah I might have an idea although not sure, I’ll try to fix it even though I can’t seem to replicate, hopefully will be fixed.
I discovered it only happens when the menu is floating with the new option vs pinned to the top as in previous versions. When the menu is pinned, it works just fine.
