Hi all,
Can you help me to understand my fault?
I followed this great tutorial https://youtu.be/DVFReH-APj8?si=bInWxiL_aO_ld9PT but in my case alignment is wrong
Hi all,
I believe you have your pivot point set in the correct orientation, but not the right position on the healing cap(?). It looks like it is on the top (closed end) of the cap and it should be on the bottom (open end).
Move the pivot down to the open end. Then, using the Reset button, it should be placed correctly on the implant.
Current pivot is on Orange Arrow. It should be on Yellow Arrow.
Hi Roger, in photos my pivots placement (the same in video). The cylinder has a through hole. But, as in video, the alignment is wrong. Can you help me to understand better?
If I’m not mistaken, one of your pivots is incorrect for what you’re wanting to do or perhaps you need to move the implant to origin. I would check both, starting with moving both to origin. This would tell you how they’re aligning and which you need to adjust.
It’s a lot to write out in order to explain…
